I seen Louis model designs about 6 months ago and have admired his building techniques. I have a few models that i'm working on at present, so thought i'd share what i have been doing.
First up is the Watts New, it's a model that was inspired by the smaller version of the Watts Up. A gent (Brian) in the UK has made plans for it and you can contact him through rcgroups by searching for "Watts New".
Its classified as an F5J model with a wing span of just under 4meters, made up of pod/boom fuselage, I'll be using a carbon boom for mine as seen in the first images. AUW i'm planning to be just on the 2kg weight, give or take some. A little heavier is no problem, the thermal activity in Oz is very aggressive. Section is MH30 and the wing is skinned with 1.5mm balsa then cover at 45deg with 3/4oz glass to provide strength.
I have a great lazer cutter friend here in Oz and he has cut most of the parts to make this quicker to pop together. I do prefer to cut everything myself, but through some communication with Brian we established that we could have it done locally.
So starting with the smaller parts to get the brain going, the rudder and elevator.
Elevator, was really easy and quick.
Steve
Rudder provides some thought, i'm considering the small bolts (in bottom of image) to secure the rudder post.
